Heya guys every time i try to batch bake a AO pass on my objects maya just gives me an error message dont have a clue what to do 😞
mental ray for Maya 2015
mental ray: version 3.12.1.16, May 6 2014, revision 219245
API 0.0 8 MB warn 302017: illegal argument "occlusionDeepBias" for function call to "maya_lenslightmap"
DISP 0.1 72 MB fatal 211109: runtime exception 0xc0000005: access violation
// Error: *Fatal* (mental ray) : mental ray encountered a fatal error. The system may have become unstable. Please save the scene and exit Maya. //
// Error: (Mayatomr.Output) : failed during mental ray rendering: mental ray abort //
Any help would be much apperciated 🙂
From what I see, MentalRay may be trying to perform something complex and may be lacking in resources.
I just conducted a sample test render on a few objects with 'Batch Bake'.
That seems to work for me with AO applied to the objects.
Can you do a similar test to narrow down the issue.
If you do manage to render the simple test, then it would point to the actual scene which may be due a setting set too high for calculation.
I would personally break the scene up in groups to render those separately
Best regards,
