I'm trying to help a colleague set up backburner so that other PCs in our office can assist with his renders. Only his PC has 3DS Max 2014 installed (currently a trial version), and on another two PCs I've installed Backburner 2014 from here: http://images.autodesk.com/adsk/files/backburner2014.0.0_1635.zip (I assume I don't need full-blown copies of 3DS Max taking up space on every PC in the office if they're only going to be render slaves?)
I've followed this autodesk documentation and I've run the Manager on my PC and also three copies of the Server on 1) my PC, 2) the 3DS Max user's PC and 3) one other PC in the office. (Idealy I'd like the Manager to run from his PC, but if I do that it reports errors of "ERR Could not bind private multicast socket on 'eth0' / 'lo' ... An attempt was made to access a socket in a way forbidden by its access permissions.")
When he clicks "Submit To Network Rendering..." in the Network Job Assignment window only his PC appearrs in the server list - but if I run the Backburner Monitor on my PC all three servers are listed. When he starts the job his PC does all the procesing and the Monitor shows that the other two Servers remain idle.
Thanks for any advice on how this can be fixed 🙂
Ok, thank you. I'll try installing it on more PCs around the office.
Any idea about the private multicast socket / access permissions error that we were seeing?
