Show only
Search instead for
Problem, I have only 3 lights in scene. All are keyed to start at zero intensity and ramp up by about the 2nd -3rd second. graph editor shows this change over time, but my render does not. Is this something simple? see attachment
Make sure you have no other lights in the scene. Turn on All lights in the viewport (7) and you should be able to preview the result. If it´s not working in the viewport, it's not your render settings, could be an extra light illuminating your scene.
Hey, thanks for the replys. I discovered my problem while I was looking at the channel box. I had the lights disabled. I reenabled the lights and the intensity changes worked as planned. So much to do. so much to learn. Dont ask why I had turned the lights off...please. chris
