I do not see a method of adding additional tags to a screencast, for example, I would like to add a tag for AU2014.
Solved by ram.mummidi. Go to Solution.
You can choose "Autodesk University" from the category drop-down to tag as AU Screencast. Hope this helps.
Thanks, --Ram
Thanks, --Ram
So, I set the Category to Autodesk University and then go to Explore Screencast and Search on Autodesk University category.
No results?
OK, the Search is working now - finding AU category.
I was having trouble with my internet connection this morning.
