At the beginning of this Screencast, I select the Gable tool, an AutoCAD Architecture out-of-the-box tool palette tool from the out-of-the-box tool Massing palette. This tool runs the MassElementAdd command, with the default Shape set to Gable. In the command listing at the left side of the Screencast, it shows as Sphere. Not a huge deal, but if it is taking the name from the name of the tool, it should show Gable.
Hi @David_W_Koch,
We report the commands based on how the command comes through the command pipeline and it looks like based on the Screencast, the command is coming down as Sphere. I will have to debug with this external third party tool to see how this commands comes down.
What do you see, when you select the other tools in that Tool palette? Are rest of the commands being captured correctly?
--Ram
It appears that all of the tools are called out as SPHERE, including the Sphere tools. The command name in AutoCAD Architecture is MassElementAdd. I can see where it may not be possible to pull the sub-command choice being executed by the tool, in which case I would expect to see MassElementAdd as the command executed, not SPHERE.
