Hi guys,
Just a general query this time, not been able to find the answer anywhere. I'm currently compiling my swf using Flash Player 12.0, and am sending data through Scaleform as JSON, but the native JSON class (which appeared in version 11.0) seems to be giving me errors in Unity, which obviously is because that JSON class isn't supported by whatever version of Flash Player Scaleform is built with/for. Tried using version 11.0 also, but got the same error:
"ReferenceError: Error #1065: Variable JSON is not defined."
Which in turn seems to cause:
"The method Stage::displayStateSet() is not implemented
UnityEngine.Debug:Log(Object)
Scaleform.SFManager:HandleASTraces() (at Assets/Plugins/SF/SFManager.cs:439)"
So my query is: What is the maximum version of Flash Player that Scaleform actually supports? May be worth adding to your FAQ section on main site also.
