Hi, I am getting an error when I have more than one scaleform render texture at once. The error doesn't show up until after I press the stop button in the editor. The error reads:
"refCount == (rs->m_Texture ? 1 : 0)
refCount == 0"
Anyone come across this or know how to fix?
Thanks!
Solved by adam.petrone. Go to Solution.
This error message should be safe to ignore. We will fix it in a future version. Here's a summary from one of our engineers:
"Movies are not destroyed when the user stops the play simulation. For RTT movies in D3D mode, Scaleform is still keeping a reference to textures. These movies should be released when the simulation is started again or when the editor is closed. If the RTT movies are destroyed before the simulation is closed (perhaps by clicking on a button) then the error should disappear."
I hope that helps shed some light on it.
We have this error message with RTT using the nearest version!
Please help
