I want to ask about how i can change yielding strength for reinforcement ! i work on yielding strength 410 Mpa not 460 !
the second question , it was easy to add new diameter bar in verison 2010 ! but now i can't ! is there any way to add new diameter bar ?
thanks in advance
Solved by Rafal.Gaweda. Go to Solution.
Tools/ Job preferences/ Material. Select material name to be changed, give new name, change yield strength. Select ADD!
I did but it's not appear .. just two options available R=plain 250Mpa & T=deformed 460 Mpa
You're right. It seems that we should change the information in the database (under Job preferences) for reinforcement bars by copying and renaming an existing code database and add a new material. I'm sorry but I didn't find any tool for that.
What about yielding strength ??
yielding strength value is 460 Mpa .. but i want to change it to 410 Mpa ?
i really did , but there's nothing change ! i'm confused
thanks anyway .. my appreciate 🙂
Try to edit the .xml file with a text editor using the reemplace function.
Thanks Rafal. M - please save the database file with a new name after change of yield stress value. Don't mess up the original one. Then select the database file and set as current database.
Yield strength refers to an indication of maximum stress that can be developed in a material without causing plastic deformation.
