Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
yielding strength
14 REPLIES 14
Message 1 of 15
MUHANNAD.ABU_ABDO
1159 Views, 14 Replies
yielding strength
I want to ask about how i can change yielding strength for reinforcement ! i work on yielding strength 410 Mpa not 460 !
the second question , it was easy to add new diameter bar in verison 2010 ! but now i can't ! is there any way to add new diameter bar ?
thanks in advance
Muhannad M.Abu Abdo
Structural Design Engineer
14 REPLIES 14
Message 2 of 15
awes
in reply to: MUHANNAD.ABU_ABDO
Tools/ Job preferences/ Material. Select material name to be changed, give new name, change yield strength. Select ADD!
Message 3 of 15
MUHANNAD.ABU_ABDO
in reply to: awes
I did but it's not appear .. just two options available R=plain 250Mpa & T=deformed 460 Mpa
Muhannad M.Abu Abdo
Message 4 of 15
awes
You're right. It seems that we should change the information in the database (under Job preferences)  for reinforcement bars by copying and renaming an existing code database and add a new material. I'm sorry but I didn't find any tool for that.
Message 5 of 15
Rafal.Gaweda
in reply to: awes
Message 6 of 15
What about yielding strength ??
Muhannad M.Abu Abdo
Message 7 of 15
Rafal Gaweda
Message 8 of 15
yielding strength value is 460  Mpa .. but i want to change it to 410 Mpa ?
Muhannad M.Abu Abdo
Message 9 of 15
So change it in rebar database.
Rafal Gaweda
Message 10 of 15
i really did , but there's nothing change ! i'm confused
Muhannad M.Abu Abdo
Message 11 of 15
CharacteristicYeldStress column
Rafal Gaweda
Message 12 of 15
thanks anyway .. my appreciate 🙂
Muhannad M.Abu Abdo
Message 13 of 15
educm4
Try to edit the .xml file with a text editor using the reemplace function.
Message 14 of 15
awes
Thanks Rafal. M - please save the database file with a new name after change of yield stress value. Don't mess up the original one. Then select the database file and set as current database.
Message 15 of 15
Yield strength refers to an indication of maximum stress that can be developed in a material without causing plastic deformation.
