Solved by Rafal.Gaweda. Go to Solution.
Can you please help me with a guide (step by step) how to use "Plate reinforcement" (-Bending, -Required, -Provided)
The manual is too old and it is not describing how to use this parts.
Take a look at movies
http://www.robotoffice.com/rsa/
Another qustion is how i can make a plate without reinforcement at the top of the plate?
Rather not possible. Minimum reinforcement will be generated.
You can also try to play with covers to get "almost" one layer reinfrocement
or with the settings below min reinforcement will not be calculated if not required (from calculation \ design point of view).
Here you are:
http://www.youtube.com/results?search_query=robot+structural&oq=robot+structural
Thanks Rafael
But I still can´t see anything describing how to work with the "Bending-/Required-/Provided- reinforcement" and what I can do in theese dialogs.
(See attached files)
/ Tord
Good example in steps:
http://www.youtube.com/watch?v=X4s-zD5FTdE
http://www.youtube.com/watch?v=sOcKRHkngH4
http://www.youtube.com/watch?v=eNDVE8laatQ
