Working with reinforcenent
6 REPLIES 6
tord
795 Views, 6 Replies
Can you please help me with a guide (step by step) how to use "Plate reinforcement" (-Bending, -Required, -Provided)
The manual is too old and it is not describing how to use this parts.
Another qustion is how i can make a plate without reinforcement at the top of the plate?
I have no bending moments at the top (maybe very small)
Thank in advance / Tord
Tags (1)
6 REPLIES 6
Rafal.Gaweda
in reply to: tord
Take a look at movies
http://www.robotoffice.com/rsa/
Rather not possible. Minimum reinforcement will be generated.
You can also try to play with covers to get "almost" one layer reinfrocement
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
or with the settings below min reinforcement will not be calculated if not required (from calculation \ design point of view).
Rafal Gaweda
tord
in reply to: tord
Thank you, it helped a lot. there were very good videos.
Do you have more of those?
/ Tord
Rafal.Gaweda
in reply to: tord
tord
Thanks Rafael
But I still can´t see anything describing how to work with the "Bending-/Required-/Provided- reinforcement" and what I can do in theese dialogs.
(See attached files)
/ Tord
Rafal.Gaweda
in reply to: tord
