Discussion Groups
Robot Structural Analysis
Member
inter1560
Accepted Solution
Wood orthotropic/laminated wood
605 Views, 2 Replies
04-10-2012 03:17 PM
is it possible to set different oriented laminated wood characteristics? Please find it attached.
I am able to create new material and orthotropic material but for whole layer, but i can't my section devide into 3 or 5 or 7 layer oriented (example.: 0*, 90*, 0*,90*,0* degree)
Thank you in advance
Please use plain text.
Product Support
Artur.Kosakowski
Re: Wood orthotropic/laminated wood
04-16-2012 02:22 AM in reply to: inter1560
I assume that if your panel is intended to work under tension rather than bending you still could try to use the orthotropy type you indicated based on the thickness of layers in each direction and the entire thickness. Otherwise the possible solution is to use the orthotrophy definition shown on the attached picture but in such case you need to find the formulas that describe each of the stiffness (I'm sorry butt I don't have any reference to indicate).
Artur Kosakowski
Active Member
cairoliangelo
04-17-2012 06:08 AM in reply to: inter1560
For me, this is the best way for calculation of the X-Lam.
