is it possible to set different oriented laminated wood characteristics? Please find it attached.
I am able to create new material and orthotropic material but for whole layer, but i can't my section devide into 3 or 5 or 7 layer oriented (example.: 0*, 90*, 0*,90*,0* degree)
Thank you in advance
Solved by cairoliangelo. Go to Solution.
I assume that if your panel is intended to work under tension rather than bending you still could try to use the orthotropy type you indicated based on the thickness of layers in each direction and the entire thickness. Otherwise the possible solution is to use the orthotrophy definition shown on the attached picture but in such case you need to find the formulas that describe each of the stiffness (I'm sorry butt I don't have any reference to indicate).
For me, this is the best way for calculation of the X-Lam.
Hi there,
Would you mind sending me a link to the original document from which these pages are please?
Thanks in advance,
Shannon
You may check if you can find the relevant part ion one of the documents available from here:
http://www.promolegno.com/formazione/corso-edifici-multipiano-documentazione/
@cairoliangelo Is this the correct link?
