Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Wood orthotropic/laminated wood
5 REPLIES 5
inter1560
3845 Views, 5 Replies
is it possible to set different oriented laminated wood characteristics? Please find it attached.
I am able to create new material and orthotropic material but for whole layer, but i can't my section devide into 3 or 5 or 7 layer oriented (example.: 0*, 90*, 0*,90*,0* degree)
Thank you in advance
Tags (1)
5 REPLIES 5
I assume that if your panel is intended to work under tension rather than bending you still could try to use the orthotropy type you indicated based on the thickness of layers in each direction and the entire thickness. Otherwise the possible solution is to use the orthotrophy definition shown on the attached picture but in such case you need to find the formulas that describe each of the stiffness (I'm sorry butt I don't have any reference to indicate).
Artur Kosakowski
cairoliangelo
in reply to: inter1560
For me, this is the best way for calculation of the X-Lam.
in reply to: cairoliangelo
Hi there,
Would you mind sending me a link to the original document from which these pages are please?
Thanks in advance,
Shannon
Artur.Kosakowski
Hi @Anonymous
You may check if you can find the relevant part ion one of the documents available from here:
http://www.promolegno.com/formazione/corso-edifici-multipiano-documentazione/
@cairoliangelo Is this the correct link?
Artur Kosakowski
No,
The document that I have posted several years ago (that is lost..) is a part
of a book not online
Sorry.
