Can you add to WishList ability to select only in the current view in the Selection dialog?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Pawel.Pulak. Go to Solution.
Hi Roman,
the requested selection effect can be obtained using selection by window in the current view and then using "common part" of this selection with selection by some section - like HSRO 14x0.312 section on the screen capture below:
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Hi Pawel,
Thank you for your reply, but I meant something else. Please, see this video.
Roman Zhelezniak
Hi Roman,
when I have written "using selection by window in the current view" I meant the new window with part of the structure - as in this video.
Yes, but IMHO, my wish can be like a timesaver, because in this case user make a little less mouse clicks 😉 For example, checkbox with on/off In curent view only.
Roman Zhelezniak
I understand your point but it would result in additional check-box in the selection window making it even more sophisticated.
Feature idea to obtain it in more direct way registered by Rafal:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Selection-in-New-Window/idi-p/3744561
Thank you, already voted for that 🙂
Roman Zhelezniak
