- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm new to the wind simulation on robot and would like some advised. I am trying to carryout wind simulation for building and only concerned by max wind pressure and suction on the facade elements.
My steps have been as follows
- Calc wind speed for the site
- Import plan of building
- Extend model to required height
- frame model with members at corners and roof
- put cladding over the faces and roof only
- select wind simulation and generate wind loads
- select directions
- input wind velocity as calc above
- select cladding panel elements only
- run simulation and calculation
After running calculation I noticed that I have wind load on faces and edges. For example see Y+ I have a wind load pressure on face of 0.88 but on edges i have wind suction of -0.4, 0.36 & 0.57. Why am I getting loads on edges is this correct?
My questions are as follows:-
- Is my procedure/steps correct?
- why am I getting load on edges of panels? and why in opposite direction
- Do I need to split cladding panels into storey heights and add horizontal floors - see model 2
- When I do this I get different results, why is this different?
- Is this more accurate?
- This is for external wind load only and Cpi should be manual calculated and added to this.
- I have external vertical features to add to panels, can I add and will this be correct if I run simulation? In the code it specifies a Cpe of 2.0 for these.
This appears a very useful tool if I have external features fixed to buildings and I hope it will produce more accurate results.
I have to provide feedback by the end of the week so I would really appreciate some feed back for the above.
The files can be downloaded form the following link.
May be you could review as I have read many of your posts.
