Discussion Groups
Robot Structural Analysis
Distinguished Contributor
gustavo.c.vasconcellos
Re: Wind Load
12-20-2012 05:12 AM in reply to: refaat
Are the loads transfered from CBS to Robot?
Gustavo
Please use plain text.
Product Support
Artur.Kosakowski
Re: Wind Load
12-20-2012 05:30 AM in reply to: gustavo.c.vasconcellos
You can export models (with loads) from CBS to Robot or calcalculate them in CBS using Robot or its calculation engine.
Artur Kosakowski
toha_mh
Re: Wind Load
12-25-2012 02:12 AM in reply to: Artur.Kosakowski
Thanks to everybody. I defined the wind loads manually on claddings as Artur suggested. But still there are a few problems.
1. If there are shear walls in some parts of a face, should I need to draw cladding over the shear walls also or I can stop at the beginning edge of shear wall?
2. After I defined all the wind loads, it takes too much time to calculate. Before applying wind load it took 5.5 minutes, but now it takes 20 minutes. And most of this time is consumed in "applying loads" stage. Is it normal, or there is any problem?
I mean, upto now I only defined loads for each cases separately. When I combine them, then it will take even more time.
Re: Wind Load
12-25-2012 07:06 AM in reply to: toha_mh
Toah_mh
as I said before, I use NV code and it doesn't take to much time to calculate. Just give a try.
Gustavo
toha_mh
Re: Wind Load
12-26-2012 01:37 AM in reply to: gustavo.c.vasconcellos
Hi, can you please give a short instruction how I can use it? I don't have any idea?
