Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Wind load on gable, temporary roof
3 REPLIES 3
Jonsereds
272 Views, 3 Replies
Im investigating mounting loads and effects from snow and wind loads on a temporary roof.
I constructed the frame in 2D and added some wind and snow load (generate 3D) from the special load tab under the load bar.
My question: Looking at the wind load on the gable, there is no load added directly on the gable but instead there is two different loads in the z-direction. Why is it so? One of them are the usual lifting force but the other one i have hard to derive the origin of?
Br. Jesper
3 REPLIES 3
Rafal.Gaweda
in reply to: Jonsereds
One load - load applied to cladding \ panel ?
Another - forces generated on bars from this load
If it is not the case please send the model
Rafal Gaweda
Jonsereds
Shouldn´t one of the loads act in the y-direction to correspond the gable wind?
Thank you for quick answer,
Rafal.Gaweda
I do not know what you have applied and what you have expected to apply.
That's why I asked for the file.
Rafal Gaweda
