Hi!
If I have very wide beams, and they are overlapped with panels above (like T section). Problem is that in such case I get a lot of extra (overlapped) mass (and weight of course).
My idea to model linear negative force, over such bars (linear force is "lifting" the beams). I would put it in self-weight load case and magnitude of such forces would be equal to overlapped section.
Is there a better way to do this, maybe some tool already built-in that I don't know about?
Solved by Rafal.Gaweda. Go to Solution.
Nice 😉 That's an interesting solution. I'll keep that in mind.
I could calculate percentage of reduction and apply it only on that part of structure (on beams).
I should have thougt of that. 😄
Thanks!
