Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
What might be reason for Check value not being zero
10 REPLIES 10
Message 1 of 11
nany717
453 Views, 10 Replies
Hi
I have modeled a simple container configuration, in which i have to test for the reactions when subjected to accelerations. When I solve the model, i can see the sum of reactions is not equal to the sum of forces.
What might be the reasons for this mismatch !? can someone point out, where I went wrong !
I have attached the model for reference.
10 REPLIES 10
Message 2 of 11
Artur.Kosakowski
in reply to: nany717
Ignored instability due to wrong material properties.
BTW: check if RECT_1 section is defined correctly (values should be in mm or cm)?
Artur Kosakowski
Message 3 of 11
nany717
in reply to: Artur.Kosakowski
Yes Artur,
I intentionally created a dummy material without any properties, or very very less values for all the properties.
How else can I model a container (of 25 ton weight) sitting on beams (HEB300), which are fastened to the deck/floor by welding ?
The problem arises only with Y+/Y- acceleration cases, for the rest of the cases, it is giving the results as expected. Also, when I change the support spring stiffness even by 1kN/m value, the error is getting bigger and bigger. Please guide.
Message 4 of 11
Artur.Kosakowski
As a nodal mass in its center of gravity with rigid links to connect it to the beams?
Artur Kosakowski
Message 5 of 11
nany717
Yes, like that...
Message 6 of 11
nany717
Also, Artur
Is there any problem in using Spring supports instead of Pinned/Fixed. I am seeing some odd reactions.
Will there be any internal reactions generated because of the springs ?!
Message 7 of 11
Artur.Kosakowski
Should not be. Any instability reported?
Artur Kosakowski
Message 8 of 11
nany717
No instability reported.
I have attached the file.
See case2: HP Pump Weight. Check the reactions in Y direction. Strange!
This is the dead weight sitting on two beams, from your earlier suggestions, I am using good material properties.
Message 9 of 11
Artur.Kosakowski
I'd define the rigid link in a different way.
Artur Kosakowski
Message 10 of 11
nany717
I can see that the unwanted reactions got reduced.
but still, why am I getting those reaction forces in Y when I am applying Z acceleration on added mass ?!
Message 11 of 11
Artur.Kosakowski
Due to the small bending of dummy bars at the locations with no rigid links which could not be defined as you already defined other rigid links there. If this is a concern you can replace one group of them with rigid bar elements.
Artur Kosakowski
