hello to all .. when i beam bridge i found this problem .. so what is the solution for this problem
thanks a lot
i want to upload the file .. but the size is bigger than the allowable ?
PLease check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Sending-bigger-files/td-p/3795062
http://www.filemail.com/d/hyhqrhuurqzpaez
Add supports to model
Mesh poperly model
Corrected model attached.
Many thanks ... i appreciate
By th way .. how you correct the mesh ?
Really great great ... many many thanks dearest sir .. i appreciate to you
excuse me sir can you tell me how i can add joint to continuous bridge ??
joints used in concrete between panels .. like expansion joint
i want to ask you .. i want to prevent moment over supports and i also make releases for beams and linear releases for panles .. but it's not work ... what is the problem ?
http://www.filemail.com/d/eurqrtkcviblnno
because time is over .. nevermind this is a new link ... i'm grateful to you anyways
http://www.filemail.com/d/qiudtzifhmgdmnq
the question is : how i can do the release for panles ? it's not for panels . it's for bars and the bars is extended over the girder ... i can't assign girder between the piers it will be sperate structure and unstable .. if i make as in the exapmle the will i find instability nodes also
