Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
what is the robot prog-id
6 REPLIES 6
minamaher20
483 Views, 6 Replies
I want to capture a running instance of robot structure analysis (specefically the one created by revit "send model to robot analysis") i did some research and i found that revit create an instance of IRobotApplication in the Running Objects Table (ROT) and that i should use :
system.runtime.interopservices.marshal.getactiveobject("Prog-ID")
now the problem is i can't find the prog id for IRobotApplication there is only a CLSID which cannot be used
I Don't Need The Prog-ID It Self I Need A Way To Capture A Running Instance Of ROBOT Application
6 REPLIES 6
Rafal.Gaweda
in reply to: minamaher20
Just attach to running robot.exe.
Only one robot \ robot .exe should be running in case of using API, otherwise you may get unwanted effects.
Rafal Gaweda
minamaher20
in reply to: Rafal.Gaweda
Sorry But How To Do That Exactly. i want to retireve an IRobotApplication Interface Object to work with from the running application instance.
Rafal.Gaweda
This ?
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
If Not RobApp.Visible Then
    Set RobApp = Nothing
    MsgBox "Open Robot", vbOKOnly, "ERROR"
    Exit Sub
End If
Rafal Gaweda
minamaher20
In C#, please ??
Rafal.Gaweda
            Robot.robApp = new RobotApplication();
            if (Robot.robApp.Visible == 0)
                MessageBox.Show("Open Robot","Error");
                this.Close();
                return;
Rafal Gaweda
minamaher20
