Discussion Groups
Robot Structural Analysis
New Member
0 Kudos
Accepted Solution
what is SOLID MODELER ? Where to buy it ?
476 Views, 3 Replies
07-11-2012 07:34 AM
hi everybody ,
as mentioned in title what is solid modeler ? and where to buy it ? to get it work in robot structural analysis .
note: i cannot use chamfer or other solid options
Product Support
760 Kudos
Re: what is SOLID MODELER ? Where to buy it ?
07-12-2012 12:02 AM in reply to: nezzus
You don't have to buy it but you may want to switch its use as the default in case it is really needed :smileyhappy:
It is http://en.wikipedia.org/wiki/ACIS
The chamfer option is available.
Artur Kosakowski
New Member
0 Kudos
07-13-2012 11:36 AM in reply to: nezzus
thanks for the reply , but it answered my problem on half .
my license is old and i'm always working with the 2010 version .
when i go to the view parameter my solid modeler options are gray ( non available )
Product Support
760 Kudos
07-16-2012 12:02 AM in reply to: nezzus
In v.2010 this option is not available. For Autodesk versions of Robot it is available since v.2011.
Artur Kosakowski
