hi everybody ,
as mentioned in title what is solid modeler ? and where to buy it ? to get it work in robot structural analysis .
note: i cannot use chamfer or other solid options
Solved by Artur.Kosakowski. Go to Solution.
You don't have to buy it but you may want to switch its use as the default in case it is really needed
It is http://en.wikipedia.org/wiki/ACIS
The chamfer option is available.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
thanks for the reply , but it answered my problem on half .
my license is old and i'm always working with the 2010 version .
when i go to the view parameter my solid modeler options are gray ( non available )
In v.2010 this option is not available. For Autodesk versions of Robot it is available since v.2011.
