Hi All,
To be honest I am really enthusiastic about to CBS, but it looks abandoned, and I cannot see further developments since the 2009 version.
The idea on which is is based is really good and covers a very important segment (perhaps the most important) in which there is no software available: The early stages of the design process of a structure. I hope that CBS will have further development or that those functions will be implemented one day in Revit.
Solved by Artur.Kosakowski. Go to Solution.
Gabriele,
You can already see the early stage of the development you proposed in form of Load Takedown Revit Extension which uses CBS engine. In addition there is the link between Revit nd CBS as well.
I am wondering where has it gone since RSA2012? Because in RSA2013 there is no more such additional program as Concrete Building Structure, has it been abandoned?
CBS 2013 is available for download from the Subscription site.
Could you be more exact to guide me where it could be downloaded because everything I could choose to install from extensions was spreadsheet calculator? May be it has another name?
Is Concrete Building Structure still available? I can't see it on subscription site.
http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=19040082
But first you must log in...
First log in into Subscription Center.
Next try link:
If it will not work, then open a Case on your Subscription Center site, asking Autodesk why ACBS 2013 is not available to you.
Autodesk has a lot of mistakes in Clients Subscription Centers - eg, for three months I had no support for ARSA 2013 because there were no product assigned to my subscription contract!!!
