welded truss node connection
2 REPLIES 2
dimogrec
1395 Views, 2 Replies
I have a T truss connection with only a bending moment of 5KNm applied on the post.
The post is an RHS 100X80X5 and the chord is a SHS100X5
1) How does Robot verify the capacity of weld in this case (I tried to read the documentation here http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-561050AE-712E-4D27-8168-AD06BBD657D-1075.htm  but honestly I got lost with all these components Smiley Frustrated )
2) Is "a" the throat thickness of a weld (as described in EC3 1-8 $4.5.2) , the height of the (largest) triangle?
3) Could you explain me the difference of longitudinal and traversal weld (if I'm right longitudinal weld is the one (or two) that has direction parallel to the axes of the chord and transversal weld the weld that is directed perpendicularly to the axes of the chord). If I'm right with this, shouldn't Robot take into account the transversal weld (for bending moment) instead of checking only the longitudinal weld? I mean I have a peripheral weld or not?
4) With manual calculation (of a peripheral weld) the weld capacity is easily satisfied
In the zip you'll find rtd file of the connection and hand calculation of weld.
Thanks in advance
2 REPLIES 2
Rafal.Gaweda
in reply to: dimogrec
The rest will be checked on Monday
Rafal Gaweda
dimogrec
in reply to: Rafal.Gaweda
Thanks for the reply Rafal
After reading also this http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-7D953AA2-D6C2-4646-A5FA-A038367FE76-1074.htm  I conclude that Robot assumes the effective length of the weld as described in Cidect. Am I right?
(I also found the answer for question 3 in the help page)
