Discussion Groups
Robot Structural Analysis
0 Kudos
Warping Constant using AISC member
412 Views, 2 Replies
02-06-2013 03:15 PM
AISC members have a warping constant (Iom or Cw) = 0 using the member from the AISC database. (see below).
But when I use this member with the CSA S16-09 design code, I get results that assign a value to Cw (see below)
Where is ROBOT getting the value of Cw?
Product Support
758 Kudos
Re: Warping Constant using AISC member
02-07-2013 12:43 AM in reply to: CameronEC
It is calculated 'inside' the steel design module either based on formulas form the selected design code or the general ones for the declared section type. E.g.
Artur Kosakowski
Active Contributor
9 Kudos
02-07-2013 01:58 AM in reply to: Artur.Kosakowski
Artur,
This answer is also useful for my last post on Lateral Bucklyng of Tapered Section.
:smileyhappy:
