Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Warning: The load has not been distributed correctly.
1 REPLY 1
jokiller70
629 Views, 1 Reply
I have no idea why... Please help. File to large to post so here it is https://www.dropbox.com/s/bjv4dniosismnuf/nytt%20bygge.dwg_calc.dwg_calc.rtd?dl=0
1 REPLY 1
Rafacascudo
in reply to: jokiller70
Don´t ask me why but , just redefine cladding 1058, the one that takes the X wind , making the botton segment in Y+ direction the 1st one.It will work without warnings
Check if the panel local system remains the same as the generated distributed panel load is applied in the its local system Z direction.
PS1: to reduce the file size , save it with another name and "without results" and zip it.
PS2:for automatic wind load generation , read this 1st.   http://forums.autodesk.com/t5/robot-structural-analysis/terrain-type-wind-simulation/m-p/5238985#M26...
Rafael Medeiros
