I have this warning: “The load has not been distributes correctly, there are not objects or elements carrying the load overlap”
Could you see my file please, I can’t find the cause.
Thanks a lot,
Solved by Artur.Kosakowski. Go to Solution.
Case 3. Loads with 0 value applied to claddings. Enter e.g. Z=-5 and calculate the model again.
