Discussion Groups
Robot Structural Analysis
Valued Contributor
pevelor
Warning: Element not assigned to any story
430 Views, 2 Replies
03-05-2012 11:17 PM
Hi
After running calculations, I get an error telling me that some of my elements are not assigned to any story.
My questions are,
- Do I need to correct this or can I disregard the warning?
- What are the consequenses of disregarding it?
- How do I easely choose the correct story for each element?
In advance, thanks.
Peder
Please use plain text.
Product Support
Artur.Kosakowski
Re: Warning: Element not assigned to any story
03-06-2012 12:18 AM in reply to: pevelor
If you  want to run seismic analysis and check results for stories then probably no; otherwise you can
See above.
You can use one of the Assign options shown on the attached picture.
Artur Kosakowski
Valued Contributor
pevelor
03-06-2012 12:40 AM in reply to: Artur.Kosakowski
Thank you
