Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Warning: Element not assigned to any story
3 REPLIES 3
pevelor
8179 Views, 3 Replies
Hi
After running calculations, I get an error telling me that some of my elements are not assigned to any story.
My questions are,
- Do I need to correct this or can I disregard the warning?
- What are the consequenses of disregarding it?
- How do I easely choose the correct story for each element?
In advance, thanks.
Peder
3 REPLIES 3
Artur.Kosakowski
in reply to: pevelor
If you  want to run seismic analysis and check results for stories then probably no; otherwise you can
See above.
You can use one of the Assign options shown on the attached picture.
Artur Kosakowski
pevelor
in reply to: Artur.Kosakowski
Thank you
Hi
What if some elements can not be assigned to any specific story? Attached is a picture of a structure that includes lot of elements that they start from one level and go through other stories or there are elements they start from the middle of the story?
