Discussion Groups
Robot Structural Analysis
Active Member
tamararr
warn message: isolated nodes have been found
471 Views, 7 Replies
11-15-2011 03:42 AM
Hi!I am modeling a steel S355 plate of dimensions 10000 x 4000 x 250mm. It is fixed in one of its boundaries and has 2 loads applied: one in its plane in the opposite boundary to the support and one acting perpendicularly in the middle of it.
I more or less followed the guideline for plates in robotoffice.com but when I start the calculation I get the warn message of isolated nodes in the model. I tried to solve this problem delating the nodes where the load is applied but of course, the load dissappears. If I disregard this message, I get no result when doing the calcualtion.
Hope you can help me with this.
Thank you in advance.
Tamara
Please use plain text.
Product Support
jad.dellel
Re: warn message: isolated nodes have been found
11-15-2011 04:10 AM in reply to: tamararr
Hi tamara,
can you upload your rtd file compressed please?
Thanks.
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
Active Member
tamararr
11-15-2011 04:35 AM in reply to: tamararr
Hi!
Thank you for the fast answer. I tried again but instead of defining the nodes for applying the loads, I used the  "force in point" command. I got a result but I am not sure if this is the best way to model the plate. It is a solid steel plate and I followed these steps:
Volumetric structure design
Axis definition
Polyline/contour
Panel-and press a point inside the contour
Extrude it to the thickness (250mm)
Fixed support (linear) in one of the 4000mm length boundaries
Defined two dead loads
Load definition-force in point (and gave the coordinates and value of the two loads)
Thank you for your help.
Tamara
Product Support
jad.dellel
11-15-2011 04:58 AM in reply to: tamararr
Tamara,
You should use the shell design ( plate design is included).
Please see http://images.autodesk.com/adsk/files/robot_2010_training_manual_metric.pdf from page n°98, It should helps you to define your plate.
I'll wait your shell model :smileyhappy:
Jad DELLEL
Active Member
tamararr
11-15-2011 06:04 AM in reply to: tamararr
Thank you very much for your help! :smileyhappy:
I attach the shell model.
Tamara
Product Support
jad.dellel
11-15-2011 06:16 AM in reply to: tamararr
Tamara,
I think your plate is designed on the wrong plane (XZ), It should be done on the (XY) plane.
Please check it.
Jad DELLEL
Active Member
tamararr
11-15-2011 06:22 AM in reply to: tamararr
You are totally right, thank you again!:smileyhappy:
Active Member
tamararr
11-16-2011 01:41 AM in reply to: tamararr
Hi!
I have one more question: how to check plate buckling and torsional buckling of the model?
Thank you very much!
/Tamara
