Walls automatic division
6 REPLIES 6
1085 Views, 6 Replies
Hello everyone,
I have the following question (trouble). I have a lot of vertical panels (can name it "walls") which one intersect each other, but doesn't divided in intersection lines (please, see attached image). Of course, in process of meshing I have obtained situation, when there are no common nodes in intersection lines of "walls", thus they are independent from each other.
So, have I any chance to split (divide) them automatically in iintersection to obtain common calculation nodes in lines? Any of program function (magic Rafal's macros/script) exist for this task?
To make thing clearer, I have to say, that the whole task is to calculate waffle slab of quite irregular shape with shell elements. So, I have choose the technology: RST -> RSA. But slab has a lot of elements and right now I'm in process of selecting variants (cell dimensions and other), so manual dividing in both of RSA and RST is appropriate way...
Thank you in advance!
6 REPLIES 6
Refaat
The inersection option can help to divide the panels , to get nodes at intersection lines .
as well take care for meshing option , i supposed to use (Element size ) instead of (Automatic or User) to generat the FE .
Also , you can use( Strucutral elements ) option to represent the walls , then automatically you will get nodes at intersection lines.
Refaat
in reply to: Refaat
Hello, Refaat, thanks for your reply,
Yes, but only on the top and the bottom of the wall. Nodes in the middle zone will independent from each other.
Sure, but in my general case (not one that shown on pic - its only exmaple) the slab and walls have irregular shape, so it doesn't work.
Sorry, I didn't catch what you mean
Artur.Kosakowski
Try to define lines at the intersections of the panels (you can define one and the copy it by translation too) and then mesh them.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Refaat
in reply to: Artur.Kosakowski
Hi igos
Beside Mr.Arthur's suggestion ,please see the attached .
Refaat
Hello all,
I'm sorry for late response - thank you a lot for useful advices!
I have used Artur's method for meshing; anyway - can this option (automatic division/generating nodes on intesection line) be added to wishlist? The reason is a lot of engineers using Revit for preprocessing and you haven't split walls in intersection in Revit. So, I think this option can be useful in RSA.
Thanks!
gustavo_c_vasconcellos
Hi Igos I have been looking for a way to model, design and analyse waffle slab in Revit/Robot.
Can you tell me if you find a way of doing this? If yes, how are you doing?
Gustavo
