Can you please advise why the walls under are not supporting the slab edge at a lift void. It won't provide a connection
I have ensured the analytical wall lines up perfectly with the slab edge but it doesn't seem to make a difference.
This has happened on a another project using Revit/Robot 2014 and I had to join all the slabs to edge of void walls manually.
Elliot
PLeas explain on model you sent us
I do not see any problem : red object = slab
Looks like this is in the extensions for Revit tool inside of Revit. If it is not working, I assume you will need to check to see that the analytical models of the slab opening align wtih the walls which support it. You may need to adjust the walls with the analytical wall adjustment tool to achieve this. What is the error message that the slab analysis tool give you?
