Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 20
HoshangMustafa
1390 Views, 19 Replies
Wall Model
Hi
Please find the attached file.
How can I model this wall with ARSA?
19 REPLIES 19
Message 2 of 20
jclcereno
in reply to: HoshangMustafa
You can model it via contours...
But robot seem to have problems with slanted panels. not about analysis but on the display, sometimes it has angles that makes the panels seem to float even if they are really attached to it.
Image below is the Slanted panel I modelled:
Zooming in, you can see it has display bugs, but meshing seems fine here:
Message 3 of 20
Rafal.Gaweda
in reply to: jclcereno
One corner of panel must be slightly out of panel plane.
Rafal Gaweda
Message 4 of 20
Hi Rafal
I'm sorry. I meant modelling the vertical part and the slanted part of the wall together so that I can get design results (reinforcement, etc) for both together.
Please check the attached file in the first post.
I have other questions about this problem when the modelling is completed.
Message 5 of 20
My answer was to Jade post.
To your screen shot:
Reinforcement results should be the same if you create such wall from 1 or 2 panels
Rafal Gaweda
Message 6 of 20
Hi Rafal
How can the vertical and slanted part of the wall be modelled from 1 panel?
Message 7 of 20
Draw "vertical" edge polyline and Extrude it.
Rafal Gaweda
Message 8 of 20
Hi Rafal
Thank you.
I tried modelling it from a polyline following the border points of the wall. It worked. Please find the attached file.
I followed your procedure using:
1-Extrude
2-Extrude along polyline
3-Object modification
But I couldn't model it. Please step by step instruct me how this can be done?
When exporting (my model) to Required Reinforcement of Slabs/Walls, it will displayed with (vertical and slanted part)
When exporting my model to Wall Design module, it will be appeared with a vertical wall.
In the Drawing, it's displayed as a vertical wall.
Isn't it a bug?
I wish this be solved, because I wish the best for ARSA.
Message 9 of 20
Hi Rafal
After all:
1- Can this vertical and slant wall support the fllor above (on one edge)?
2- If not, how can this wall be modelleled and how it can be supported?
Message 10 of 20
You may draw a polyline with vertical and inclined parts and extrude it horizontally to create a panel but I would suggest that you just create two panels ( a vertical one and an inclined one) instead. In this way you it will be easier for you to control meshing.
Artur Kosakowski
Message 11 of 20
Hi Artur
Thank you very much. Two panels may solve many things.
Message 12 of 20
Yes, if you create coherent meshes.
Artur Kosakowski
Message 13 of 20
Hi Artur
I'm sorry, do you mean the attached dialog?
Message 14 of 20
Assuming you have 3 panels (vertical, slanting and horizontal) you should create meshes in such a way that they are coherent (have common nodes) at their common edges. For the dialog you attached I'd recommend switching on the iterative adjustment of meshes.
Artur Kosakowski
Message 15 of 20
Hi Artur
I've encountered these errors. (incoheerent data, unknown errors). What should I do to overcome these errors?
Message 16 of 20
If you switched on the correction of deflections for these panels try to switch if off. This option makes sense for horizontal slabs only.
Artur Kosakowski
Message 17 of 20
Hi
If you mean Reinforcement correction, this option is already unchecked.
Message 18 of 20
Attach the model please.
Artur Kosakowski
Message 19 of 20
Hi Artur
Thank you.
Here you are the file, please.
http://we.tl/BStu22MKBo
Message 20 of 20
Is it the right model? I can't see any issue with calculations of reinforcement for these panels.
Artur Kosakowski
