Hi
Please find the attached file.
How can I model this wall with ARSA?
You can model it via contours...
But robot seem to have problems with slanted panels. not about analysis but on the display, sometimes it has angles that makes the panels seem to float even if they are really attached to it.
Image below is the Slanted panel I modelled:
Zooming in, you can see it has display bugs, but meshing seems fine here:
Hi Rafal
I'm sorry. I meant modelling the vertical part and the slanted part of the wall together so that I can get design results (reinforcement, etc) for both together.
Please check the attached file in the first post.
I have other questions about this problem when the modelling is completed.
Hi Rafal
Reinforcement results should be the same if you create such wall from 1 or 2 panels
How can the vertical and slanted part of the wall be modelled from 1 panel?
Hi Rafal
Thank you.
Draw "vertical" edge polyline and Extrude it.
I tried modelling it from a polyline following the border points of the wall. It worked. Please find the attached file.
I followed your procedure using:
1-Extrude
2-Extrude along polyline
3-Object modification
But I couldn't model it. Please step by step instruct me how this can be done?
When exporting (my model) to Required Reinforcement of Slabs/Walls, it will displayed with (vertical and slanted part)
When exporting my model to Wall Design module, it will be appeared with a vertical wall.
In the Drawing, it's displayed as a vertical wall.
Isn't it a bug?
I wish this be solved, because I wish the best for ARSA.
Hi Rafal
After all:
1- Can this vertical and slant wall support the fllor above (on one edge)?
2- If not, how can this wall be modelleled and how it can be supported?
You may draw a polyline with vertical and inclined parts and extrude it horizontally to create a panel but I would suggest that you just create two panels ( a vertical one and an inclined one) instead. In this way you it will be easier for you to control meshing.
Hi Artur
Thank you very much. Two panels may solve many things.
Yes, if you create coherent meshes.
Hi Artur
I'm sorry, do you mean the attached dialog?
Assuming you have 3 panels (vertical, slanting and horizontal) you should create meshes in such a way that they are coherent (have common nodes) at their common edges. For the dialog you attached I'd recommend switching on the iterative adjustment of meshes.
Hi Artur
I've encountered these errors. (incoheerent data, unknown errors). What should I do to overcome these errors?
If you switched on the correction of deflections for these panels try to switch if off. This option makes sense for horizontal slabs only.
Hi
If you mean Reinforcement correction, this option is already unchecked.
Is it the right model? I can't see any issue with calculations of reinforcement for these panels.
