Hi all.
Please check 2 modol same, But results other, Why ???/
I is send modol below
Solved by Romanich. Go to Solution.
You must use "dummy" bar under bearing wall.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
1. You should change linear load to have the same reactions
2. Bending of a T shape is not the same as bending a flat bar.
Thanks you.
If i use nonbearing wall . I should give it a wall or panels or shell or clading??????
example with nonbearing wall attached.
Roman Zhelezniak
