Wall it and load wall
6 REPLIES 6
A.wikipedia
528 Views, 6 Replies
Hi all.
Please check 2 modol same, But results other, Why ???/
I is send modol below
6 REPLIES 6
Romanich
in reply to: A.wikipedia
You must use "dummy" bar under bearing wall.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
A.wikipedia
in reply to: Romanich
You can edit the model to help me.
I is attchment model.
1. You should change linear load to have the same reactions
2. Bending of  a T shape is not the same as bending a flat bar.
Artur Kosakowski
Thanks you.
If i use nonbearing wall . I should give it a wall or panels or shell or clading??????
Romanich
example with nonbearing wall attached.
Roman Zhelezniak
A.wikipedia
Thansk you.
But i don't kwon. Why Pz= 7,65 kN/m ?????/?
