rodainnajjar1229
689 Views, 2 Replies
wall design
Dear Sir
kindly find attached file
I try  to design a RC wall with force perpendicular to its plane (( see pic1))
we have reduced force in wall with  TRZ = 3472 kN (( see pic2 ))
but when we have designed the wall using robot, it doesn't take into consideration TRZ . Only TRY was taken into consideration.((see pic3))
Regards
Tags (1)
2 REPLIES 2
The RC wall design module do not  include out of plane bending. For the load as on the attached pictures use the RC Slab Required Reinforcement module instead. Mind to include both tension/compression and bending in the reinforcement type assigned to this panel.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
thanks Artur
