Dear Sir
kindly find attached file
I try to design a RC wall with force perpendicular to its plane (( see pic1))
we have reduced force in wall with TRZ = 3472 kN (( see pic2 ))
but when we have designed the wall using robot, it doesn't take into consideration TRZ . Only TRY was taken into consideration.((see pic3))
Regards
Solved by rodainnajjar1229. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
The RC wall design module do not include out of plane bending. For the load as on the attached pictures use the RC Slab Required Reinforcement module instead. Mind to include both tension/compression and bending in the reinforcement type assigned to this panel.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
