i am having problem with walls design.
i run the program with all needs, the results are OK, when i select one wall an use the Wall Design Option it takes the walls but not all loads.
i have done this before and worked. i used different structural buildings to compare, and nothing is missing.
i have robot 2011 ans SP6
Any chance to upload the rtd file?
i can not attach the file. too large.
can you send me a structure with a foundation slab a normal slab.
and 2 walls designed?
with the example, then i can compare mine.
regards,
It seemed to me that this was a problem in your model.
But therefore it is not more justified you try to upload a file anyway?
File can be without the results and compressed.
Please try to save it also with new name.
i did the compressed file, but still 17.3 mb
in Zip mode, and the web does not allow me to upload
when i assgin a wall to a core condition and i named (M1)
in the 3d view how can i present the name of the wall (related to Core) i can do it with panel number, etc with the display module.
and i can put color to the core walls, but no named..
exist a command to do it?
i am attaching a jpg file, i can show only the color, not the core name. when i print the paper, the color near name is difficult to read a do a relation with the picture.
regards
Well, I do not think that file saved without results as new name might be so huge after compression.
Something has to be contrary to my instruction.
I am affraid that there is no other option to mark the core walls after the composing walls into a CoreWall group.
Only legend formatting lets you to present the relation between panel elements on view and the name of defined CoreWall.
