Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Viewing Results
1 REPLY 1
davidgholmes
229 Views, 1 Reply
Viewing Results
Mr Robot,
Is it possible to view map results for individual panels? I am trying to look at different panels within the same storey in closer detail, and am sure there must be a simple solution
Tags (2)
1 REPLY 1
Select a panel and open it in a new window (either prior to displaying results or mark the corresponding check box in the maps dialog). The same for selection of few surface elements if needed.
Artur Kosakowski
