Mr Robot,
Is it possible to view map results for individual panels? I am trying to look at different panels within the same storey in closer detail, and am sure there must be a simple solution
Solved by Artur.Kosakowski. Go to Solution.
Select a panel and open it in a new window (either prior to displaying results or mark the corresponding check box in the maps dialog). The same for selection of few surface elements if needed.
