Discussion Groups
Robot Structural Analysis
StuartRogers
View Tension / Compression Only Members
1196 Views, 9 Replies
10-22-2012 09:00 AM
I'm in the process of checking some ROBOT models. These models may or may not include tension only or conpression only members.
Is there a way to show these members in the view window? or another way to check whether they have been used?
I have found a way to view 'truss' members (Selection -> Bars -> Advanced -> Truss), this highlights the 'truss' members. Is there a way to do the same for 'tension only' or 'compression only' members?
I have tried the help documentation and seaching here, but haven't had any luck yet.
Thank you for your help.
Stuart
Please use plain text.
Product Support
Artur.Kosakowski
Re: View Tension / Compression Only Members
10-23-2012 12:01 AM in reply to: StuartRogers
See the attached picture.
Artur Kosakowski
StuartRogers
10-23-2012 12:27 AM in reply to: Artur.Kosakowski
Great! Thanks Artur
Distinguished Contributor
Jummybear
02-05-2013 12:24 AM in reply to: Artur.Kosakowski
One question about truss and compression/tension bars: when i use them it seems that no bending moment appears in the current bar, but what are the terms of the ends in such bar? Does it use releases on the ends automatically?
Product Support
Artur.Kosakowski
02-05-2013 12:41 AM in reply to: Jummybear
No, this is a special typ bar element with no rotational d.o.fs.
If you use releases on a standard bar you may have bending along its length despite the fact that there is no bending at its ends.
Artur Kosakowski
Jummybear
02-05-2013 12:46 AM in reply to: Artur.Kosakowski
So in some cases i need to use truss or compression/tension bar + releases at the ends?
Product Support
Artur.Kosakowski
02-05-2013 02:57 AM in reply to: Jummybear
No, as the truss members have got no rotational d.o.fs you are not allowed to define releases for moments.
On the other hand you can define standard bar with such releases (it will act as a truss bar provided no load along its length is defined) and add unidirectional release along its length (tension/compression only action).
Artur Kosakowski
Active Contributor
85778RSAPRO_2012_0F
02-26-2013 03:19 AM in reply to: Artur.Kosakowski
Hi, I tried to do that but when I chosse: selecstion>bars>advanced there is no more choises. How can I define some members as a tension members?
Thanks for help
Waleed Khalid
Product Support
Artur.Kosakowski
02-26-2013 03:29 AM in reply to: 85778RSAPRO_2012_0F
Artur Kosakowski
Active Contributor
85778RSAPRO_2012_0F
02-26-2013 03:41 AM in reply to: Artur.Kosakowski
Thanks :smileyhappy:
Waleed Khalid
