Dears
I need help in where i can find a command of view only the selected member , elements or parts of the structure which is very common in other applications ?
Solved by Rafacascudo. Go to Solution.
Solved by StefanoPasquini6790. Go to Solution.
Solved by HoshangMustafa. Go to Solution.
Hi
1-Select the member
2- use the indicated tool in the attached file
Well, this is one of the possibility to hide part of the structure, the most helpfull one is this:
1) click on RMB and chose the visualization tool (as showed in the following picture:
2) after clicking in the highlighted point, you can see this label:
3) Well, now you can change whatever you want and the visualization is referred only at the selected bars, obviously changing selection it change the view and not the property (see the next picture)
Hope I help you, greetings.
Select the elements and click on " Edit on new window" . Only the selected elements will show up in the new window
Rafael Medeiros
Hi
The 1st post was this:
Ther's the word of (only)
Hi HoshangMustafa , Our answers are the same.I wouldn´t send it if I had seen your attached picture !
Rafael Medeiros
ok, so you just clicked the wrong reply button
Rafael Medeiros
Hi
There's the word of (only)
