Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
view selected member only
9 REPLIES 9
Message 1 of 10
waleedations
1975 Views, 9 Replies
Dears
I need help in where i can find a command of view only the selected member , elements or parts of the structure which is very common in other applications ?
9 REPLIES 9
Message 2 of 10
In the visualization label you can find the option "only for selected object". On screen click with the RMB and find the visualization panel.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 10
Hi
1-Select the member
2- use the indicated tool in the attached file
Message 4 of 10
Well, this is one of the possibility to hide part of the structure, the most helpfull one is this:
1) click on RMB and chose the visualization tool (as showed in the following picture:
2) after clicking in the highlighted point, you can see this label:
3) Well, now you can change whatever you want and the visualization is referred only at the selected bars, obviously changing selection it change the view and not the property (see the next picture)
Hope I help you, greetings.
PasProStudio
Message 5 of 10
Rafacascudo
in reply to: waleedations
Select the elements  and click on " Edit on new window" . Only the selected elements will show up in the new window
Rafael Medeiros
Message 6 of 10
Hi
The 1st post was this:
Ther's the word of (only)
Message 7 of 10
Hi HoshangMustafa , Our answers are the same.I wouldn´t send it if I had seen your attached picture !
Rafael Medeiros
Message 8 of 10
Hi
My reply was for StefanoPasquini790.
Message 9 of 10
ok, so you just clicked the wrong reply button
Rafael Medeiros
Message 10 of 10
Hi
There's the word of (only)
