Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Very slow сopying of elements
8 REPLIES 8
Message 1 of 9
Romanich
565 Views, 8 Replies
how we can speed up copy/move elemenets in Robot model? I need to copy set of panels and lines from column to column and it's very very slow. Maybe I didn't know some trick Smiley Wink
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Tags (3)
8 REPLIES 8
Message 2 of 9
Artur.Kosakowski
in reply to: Romanich
Try to switch undo off. You may need to restart Robot.
Artur Kosakowski
Message 3 of 9
Romanich
in reply to: Artur.Kosakowski
Artur, nothing happens...
Roman Zhelezniak
Message 4 of 9
Artur.Kosakowski
Try to switch off display of interiors and thicknesses on ALL VIEWERS (mind that for the building model the viewer has got TWO tabs) including the additional ones you opened.
Artur Kosakowski
Message 5 of 9
Romanich
Artur, this didn't help me. Also I'm tried to switch off selection synchronization between views, but this didn't help too.
Roman Zhelezniak
Message 6 of 9
Artur.Kosakowski
Please make sure you switched off display of these attributes on ALL viewers. I have tested this on my computer before posting the answer to check it works. Please send me the screen capture that shows how your screen (in Robot) looks like just before trying to run copying.
Artur Kosakowski
Message 7 of 9
Romanich
This is a screen:
On a Plan view settings the same.
Please, try to copy elements  8309to8336  for example.
Also, when I'm working in English language version of Robot, after each save Robot show this dialog:
Roman Zhelezniak
Message 8 of 9
Artur.Kosakowski
See the movie
http://screencast.com/t/5sXngzMdzO
Before opening the Display dialog I pressed the default display button to make sure that I have the control over the settings you made in the file.
Artur Kosakowski
Message 9 of 9
Romanich
Thank you, Artur! Last trick has decided my issue.
Roman Zhelezniak
