Discussion Groups
Robot Structural Analysis
*Expert Elite* | International Moderator
Romanich
Very slow сopying of elements
307 Views, 8 Replies
07-06-2012 02:06 AM
how we can speed up copy/move elemenets in Robot model? I need to copy set of panels and lines from column to column and it's very very slow. Maybe I didn't know some trick :smileywink:
Please use plain text.
Product Support
Artur.Kosakowski
Re: Very slow сopying of elements
07-06-2012 02:14 AM in reply to: Romanich
Try to switch undo off. You may need to restart Robot.
Artur Kosakowski
Romanich
07-06-2012 02:22 AM in reply to: Artur.Kosakowski
Artur, nothing happens...
Product Support
Artur.Kosakowski
07-09-2012 05:30 AM in reply to: Romanich
Try to switch off display of interiors and thicknesses on ALL VIEWERS (mind that for the building model the viewer has got TWO tabs) including the additional ones you opened.
Artur Kosakowski
Romanich
07-09-2012 05:37 AM in reply to: Artur.Kosakowski
Artur, this didn't help me. Also I'm tried to switch off selection synchronization between views, but this didn't help too.
Product Support
Artur.Kosakowski
07-09-2012 06:40 AM in reply to: Romanich
Please make sure you switched off display of these attributes on ALL viewers. I have tested this on my computer before posting the answer to check it works. Please send me the screen capture that shows how your screen (in Robot) looks like just before trying to run copying.
Artur Kosakowski
Romanich
07-09-2012 06:54 AM in reply to: Artur.Kosakowski
This is a screen:
On a Plan view settings the same.
Please, try to copy elements  8309to8336  for example.
Also, when I'm working in English language version of Robot, after each save Robot show this dialog:
Product Support
Artur.Kosakowski
07-10-2012 02:31 AM in reply to: Romanich
See the movie
http://screencast.com/t/5sXngzMdzO
Before opening the Display dialog I pressed the default display button to make sure that I have the control over the settings you made in the file.
Artur Kosakowski
Romanich
07-10-2012 03:05 AM in reply to: Artur.Kosakowski
Thank you, Artur! Last trick has decided my issue.
