Hello, with Autodesk Simulation there's a PDF file where you could validate the accuray of the software using engineering books samples.
With Robot is there any similar?
The training guide is ok, but Is there any samples where I could validate if I'm wrong or right.
I am trying to compare the modal results from a seisme engineering book and I don`t find similar results....
any idea?
regards
Solved by Artur.Kosakowski. Go to Solution.
Check the message 3.
