VERIFY ACCURATE- MODAL ANALYSIS SAMPLES
1 REPLY 1
jorge.lopera
479 Views, 1 Reply
Hello, with Autodesk Simulation there's a PDF file where you could validate the accuray of the software using engineering books samples.
With Robot is there any similar?
The training guide is ok, but Is there any samples where I could validate if I'm wrong or right.
I am trying to compare the modal results from a seisme engineering book and I  don`t find similar results....
any idea?
regards
Technical Specialist
Nexsys de Colombia
1 REPLY 1
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autodesk-Robot-Verification-and-Theory/m-p/3...
Check the message 3.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
